Group: DynoMotion Message: 11651 From: Anatoliy Rohalskiy Date: 6/6/2015
Subject: Отв: [DynoMotion] Problem with 5th axis
Thank you very much. Everything works
And the next questions
How to understand the setup of rotary axes with "degrees" or without it?
In theory, I understand, but how it works
пятница, 5 июня 2015 22:12 "Moray Cuthill moray.cuthill@... [DynoMotion]" <DynoMotion@yahoogroups.com> писал(а):
the problem is the DefineCoordSystem function is only good for 4 axis. To use 5 axis, you have to use DefineCoordSystem6, and set the sixth axis to -1, same as you would with DefineCoordSystem function if not using 4 axis..
The relevant extract from the KMotionDef.h file is -
Moray
On Fri, Jun 5, 2015 at 7:46 PM, bigrid_rid@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
[Attachment(s) from bigrid_rid@... [DynoMotion] included below]
I have a next error.What am I doing wrong? Four axes - normally. but the fifth axis error when I wrote it being prescribed in Init.c file
Group: DynoMotion Message: 11653 From: Tom Kerekes Date: 6/6/2015
Subject: Re: Отв: [DynoMotion] Problem with 5th axis
Hi Anatoliy,
Please ask more specific questions.  Have you read this:
